Complete Bidirectional Typing for the Calculus of Inductive Constructions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
This article presents a bidirectional type system for the Calculus of Inductive Constructions (CIC). It introduces a novel judgement intermediate between the usual inference and checking, dubbed constrained inference, to handle the presence of computation in types. The key property is the completeness of the system with respect to the usual undirected one, which has been formally proven in Coq as a part of the MetaCoq project. Although it plays a central role in an ongoing completeness proof for a realistic typing algorithm, the interest of bidirectionality is much wider, as it clarifies previous works in the area and gives strong insights and structure when trying to prove properties on CIC or design variations and extensions.
main.pdf (871.13 Ko) Télécharger le fichier
hal-03139924 , version 1 (12-02-2021)
hal-03139924 , version 2 (19-04-2021)
  • HAL Id : hal-03139924 , version 1
Meven Lennon-Bertrand. Complete Bidirectional Typing for the Calculus of Inductive Constructions. 2021. ⟨hal-03139924v1⟩
155 Consultations
213 Téléchargements
