Locality-Aware Scheduling of Independant Tasks for Runtime Systems
Ordonnancement de tâches indépendantes pour support d’exécution utilisant la localité des données
A now-classical way of meeting the increasing demand for computing speed by HPC applications is the use of GPUs and/or other accelerators. Such accelerators have their own memory, which is usually quite limited, and are connected to the main memory through a bus with bounded bandwidth. Thus, a particular care should be devoted to data locality in order to avoid unnecessary data movements. Task-based runtime schedulers have emerged as a convenient and efficient way to use such heterogeneous platforms. When processing an application, the scheduler has the knowledge of all tasks available for processing on a GPU, as well as their input data dependencies. Hence, it is able to order tasks and prefetch their input data in the GPU memory (after possibly evicting some previously-loaded data), while aiming at minimizing data movements, so as to reduce the total processing time. In this paper, we focus on how to schedule tasks that share some of their input data (but are otherwise independent) on a GPU. We provide a formal model of the problem, exhibit an optimal eviction strategy, and show that ordering tasks to minimize data movement is NP-complete. We review and adapt existing ordering strategies to this problem, and propose a new one based on task aggregation. These strategies have been implemented in the StarPU runtime system. We present their performance on tasks from tiled 2D, 3D matrix products, Cholesky factorization and randomized 2D matrix operation. Our experiments demonstrate that using our new strategy together with the optimal eviction policy reduces the amount of data movement as well as the total processing time.
Une manière désormais classique de répondre à la demande croissante de puissance de calcul par les applications HPC est l'utilisation de GPU et autres accélérateurs. Ces accélérateurs ont leurs propre mémoire, qui est généralement assez limitée, et sont connectés à la mémoire principale via un bus dont la bande passante est bornée. Ainsi, une attention particulière doit être portée à la localité des données afin d'éviter des mouvements de données inutiles. Les ordonnanceurs des supports d'exécution à base de tâches sont un moyen pratique et efficace d'utiliser de telles plateformes hétérogènes. Lors du traitement d'une application, l'ordonnanceur a la connaissance de toutes les tâches disponibles, ainsi que leurs dépendances. Ainsi, il est capable d'ordonner les tâches et de pré-charger leurs données d'entrée dans la mémoire du GPU (après avoir éventuellement évincé certaines données précédemment chargées), tout minimisant les transferts de données, afin de réduire le temps d'exécution total. Dans ce papier, nous nous concentrons sur la façon de planifier des tâches qui partagent des données (mais sont par ailleurs indépendantes) sur un GPU. Nous fournissons un modèle formel du problème, nous présentons une stratégie d'éviction optimale et nous montrons qu'ordonner des tâches afin de minimiser les mouvement des données est un problème NP-complet. Nous adaptons des stratégies d'ordonnancement existantes à ce problème, et nous en proposons une nouvelle basé sur l'agrégation des tâches. Ces stratégies ont été implémentées sur le support d'exécution StarPU. Nous présentons leurs performances sur des produits matriciels 2D, 3D, la factorisation de Cholesky et un produit matriciel 2D randomisé. Nos expériences démontrent qu'en utilisant notre nouvelle stratégie, avec la politique d'éviction optimale, nous réduisons la quantité de transferts de données ainsi que le temps de traitement total.
