An Artificial Compressibility Based Approach to Simulate Inert and Reacting Flows
An efficient methodology to simulate non-reactive and reactive flows is presented. Combining a finite-volume approach on fully staggered meshes along with the artificial compressibility method, the resulting code proves to be versatile enough to cope with flow configurations ranging from unsteady cylinder wakes, heated cylinder or steadyand unsteady diffusion flames with excellent accuracy, in the limits of the underlying physical modelling.
