Draft genome and description of Negativicoccus massiliensis strain Marseille-P2082, a new species isolated from the gut microbiota of an obese patient - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Antonie van Leeuwenhoek Année : 2020
Strain Marseille-P2082, an anaerobic, non-motile, asporogenous, Gram-negative, coccoid bacterium was isolated from the faeces of a 33 year-old obese French woman before bariatric surgery. The isolate exhibits 98.65% 16S rRNA gene nucleotide sequence similarity with Negativicoccus succinicivorans strain ADV 07/08/06-B-1388(T), its current closest phylogenetic neighbour with standing in nomenclature. However, the dDDH relatedness between the new isolate and N. succinicivorans type strain ADV 07/08/06-B-1388(T) is 52.5 +/- 2.7%. Strain Marseille-P2082 has a genome of 1,360,589 bp with a 51.1% G+C content. Its major fatty acids were identified as C-18:1n9, C-18:0 and C-16:0. Based on its phenotypic, genomic and phylogenetic characteristics, strain Marseille-P2082(T) [= CSURP2082 (Collection de Souches de l'Unite des Rickettsies) = DSM 100853] is proposed as the type strain of the novel species Negativicoccus massiliensis sp. nov. The 16S rRNA gene sequence and whole-genome shotgun sequence have been deposited in EMBL-EBI under accession numbers LN876651 and LT700188, respectively.
ANTO-D-19-00259R1 edited_final.pdf (695.16 Ko) Télécharger le fichier
MS-Fig S1.pdf (5.3 Mo) Télécharger le fichier
MS-Fig-1.pdf (88.68 Ko) Télécharger le fichier
MS-Fig-2.pdf (69.46 Ko) Télécharger le fichier
MS-Fig-3.pdf (69.98 Ko) Télécharger le fichier
MS-Fig-4.pdf (148.37 Ko) Télécharger le fichier
MS-Fig-5.pdf (20.89 Ko) Télécharger le fichier
MS-Fig-6.pdf (47.91 Ko) Télécharger le fichier
hal-03149954 , version 1 (13-05-2021)
Amadou Hamidou Togo, Awa Diop, Mamadou Lamine Tall, Matthieu Million, Saber Khelaifia, et al.. Draft genome and description of Negativicoccus massiliensis strain Marseille-P2082, a new species isolated from the gut microbiota of an obese patient. Antonie van Leeuwenhoek, 2020, 113 (7), pp.997-1008. ⟨10.1007/s10482-020-01414-5⟩. ⟨hal-03149954⟩
180 Consultations
213 Téléchargements
