A Probabilistic Framework for Modeling the Variability Across Federated Datasets of Heterogeneous Multi-View Observations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Information processing in medical imaging : proceedings of the ... conference. Année : 2021
We propose a novel federated learning paradigm to model data variability among heterogeneous clients in multi-centric studies. Our method is expressed through a hierarchical Bayesian latent variable model, where client-specific parameters are assumed to be realization from a global distribution at the master level, which is in turn estimated to account for data bias and variability across clients. We show that our framework can be effectively optimized through expectation maximization over latent master's distribution and clients' parameters. We tested our method on the analysis of multi-modal medical imaging data and clinical scores from distributed clinical datasets of patients affected by Alzheimer's disease. We demonstrate that our method is robust when data is distributed either in iid and non-iid manners: it allows to quantify the variability of data, views and centers, while guaranteeing high-quality data reconstruction as compared to the state-of-the-art autoencoding models and federated learning schemes.
Fed_mv_PPCA_ipmi.pdf (923.21 Ko) Télécharger le fichier
hal-03152886 , version 1 (25-02-2021)
hal-03152886 , version 2 (24-03-2021)
  • HAL Id : hal-03152886 , version 1
Irene Balelli, Santiago Silva, Marco Lorenzi. A Probabilistic Framework for Modeling the Variability Across Federated Datasets of Heterogeneous Multi-View Observations. Information processing in medical imaging : proceedings of the .. conference., In press. ⟨hal-03152886v1⟩
293 Consultations
392 Téléchargements
