The curious case of a hapless mathematical contribution to biology - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
This is the story, told in the light of a new analysis of historical data, of a mathematical biology problem that was explored in the 1930s in Thomas Morgan’s laboratory at the California Institute of Technology. It is one of the early developments of evolutionary genetics and quantitative phylogeny, and deals with the identification and counting of chromosomal rearrangements in Drosophila species from comparisons of genetic maps. A re-analysis of the data produced in the 1930s using current mathematics and computational technologies reveals how a team of biologists, with the help of a renowned mathematician and against their first intuition, came to an erroneous conclusion regarding the presence of phylogenetic signals in gene arrangements. This example illustrates two different aspects of a same piece: 1) the appearance of a mathematical in biology problem solved with the development of a combinatorial algorithm, which was unusual at the time, and 2) the role of errors in scientific activity. Also underlying is the possible influence of computational complexity in understanding the directions of research in biology.
The_curious_case_with_author.pdf (515.62 Ko) Télécharger le fichier
hal-03153696 , version 1 (26-02-2021)
hal-03153696 , version 2 (21-03-2022)
hal-03153696 , version 3 (20-09-2022)
  • HAL Id : hal-03153696 , version 2
Eric Tannier. The curious case of a hapless mathematical contribution to biology. 2022. ⟨hal-03153696v2⟩
480 Consultations
258 Téléchargements
