Convolutional neural networks for the automatic quality control of brain T1-weighted MRI from a clinical data warehouse - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
Many studies on machine learning (ML) for computer-aided diagnosis are restricted to high-quality research data. Clinical data warehouses, gathering routine examinations from hospitals, offer great promises for training and validation of ML models in a realistic setting. However, the use of such clinical data warehouses requires quality control (QC) tools. Visual QC by experts is time-consuming and does not scale to large datasets. The aim of this work is to develop a convolutional neural network (CNN) for the automatic QC of 3D T1w brain MRI for a large heterogeneous clinical data warehouse. Specifically, the objectives were: 1) to identify images which are not proper T1w brain MRIs; 2) to identify acquisitions for which gadolinium was injected; 3) to rate the overall image quality. We used 5000 images for training and validation and a separate set of 500 images for testing. In order to train/validate the CNN, the data were annotated by two trained raters according to a visual QC protocol that we specifically designed for application in the setting of a data warehouse. For objectives 1 and 2, our approach achieved excellent accuracy, similar to the human raters. For objective 3, the performance was good but substantially lower to that of human raters.
QC_conf_submitted_version.pdf (1.74 Mo) Télécharger le fichier
hal-03154792 , version 1 (01-03-2021)
hal-03154792 , version 2 (13-04-2021)
hal-03154792 , version 3 (16-04-2021)
hal-03154792 , version 4 (29-08-2021)
  • HAL Id : hal-03154792 , version 1
Simona Bottani, Ninon Burgos, Aurélien Maire, Adam Wild, Sébastian Ströer, et al.. Convolutional neural networks for the automatic quality control of brain T1-weighted MRI from a clinical data warehouse. 2021. ⟨hal-03154792v1⟩
550 Consultations
786 Téléchargements
