Diverse Cell Stimulation Kinetics Identify Predictive Signal Transduction Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue iScience Année : 2020
Computationally understanding the molecular mechanisms that give rise to cellsignaling responses upon different environmental, chemical, and genetic pertur-bations is a long-standing challenge that requires models that fit and predictquantitative responses for new biological conditions. Overcoming this challengedepends not only on good models and detailed experimental data but also on therigorous integration of both. We propose a quantitative framework to perturband model generic signaling networks using multiple and diverse changing envi-ronments (hereafter ‘‘kinetic stimulations’’) resulting in distinct pathway activa-tion dynamics. We demonstrate that utilizing multiple diverse kinetic stimulationsbetter constrains model parameters and enables predictions of signaling dy-namics that would be impossible using traditional dose-response or individual ki-netic stimulations. To demonstrate our approach, we use experimentally identi-fied models to predict signaling dynamics in normal, mutated, and drug-treatedconditions upon multitudes of kinetic stimulations and quantify which proteinsand reaction rates are most sensitive to which extracellular stimulations.
1-s2.0-S2589004220307574-main.pdf (17.03 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-03155416 , version 1 (18-03-2021)
Paternité - Pas d'utilisation commerciale - Pas de modification
Hossein Jashnsaz, Zachary Fox, Jason Hughes, Guoliang Li, Brian Munsky, et al.. Diverse Cell Stimulation Kinetics Identify Predictive Signal Transduction Models. iScience, 2020, 23 (10), pp.101565. ⟨10.1016/j.isci.2020.101565⟩. ⟨hal-03155416⟩
52 Consultations
49 Téléchargements
