Shape optimization of a Dirichlet type energy for semilinear elliptic partial differential equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Control, Optimisation and Calculus of Variations Année : 2021
Minimizing the so-called "Dirichlet energy" with respect to the domain under a volume constraint is a standard problem in shape optimization which is now well understood. This article is devoted to a prototypal non-linear version of the problem, where one aims at minimizing a Dirichlet-type energy involving the solution to a semilinear elliptic PDE with respect to the domain, under a volume constraint. One of the main differences with the standard version of this problem rests upon the fact that the criterion to minimize does not write as the minimum of an energy, and thus most of the usual tools to analyze this problem cannot be used. By using a relaxed version of this problem, we first prove the existence of optimal shapes under several assumptions on the problem parameters. We then analyze the stability of the ball, expected to be a good candidate for solving the shape optimization problem, when the coefficients of the involved PDE are radially symmetric.
HMP.pdf (684.89 Ko) Télécharger le fichier
hal-03155540 , version 1 (06-11-2019)
hal-03155540 , version 2 (09-04-2020)
hal-03155540 , version 3 (01-03-2021)
  • HAL Id : hal-03155540 , version 2
Antoine Henrot, Idriss Mazari, Yannick Privat. Shape optimization of a Dirichlet type energy for semilinear elliptic partial differential equations. ESAIM: Control, Optimisation and Calculus of Variations, 2021, 27 (S6). ⟨hal-03155540v2⟩
521 Consultations
308 Téléchargements
