Computing Difference Abstractions of Linear Equation Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
Emilie Allart
Joachim Niehren
Cristian Versari
  • Fonction : Auteur
  • PersonId : 943051
Interpretation was proposed for predicting changes of reaction networks with partial kinetic information in systems biology. This requires to compute the set of difference abstractions of a system of linear equations under nonlinear constraints. We present the first practical algorithm that can compute the difference abstractions of linear equation systems exactly. We also present a new heuristics based on minimal support consequences for overapproximating the set of difference abstractions. Our algorithms rely on elementary modes, first-order definitions, and finite domain constraint programming. We implemented our algorithms and applied them to change prediction in systems biology. It turns out experimentally that the new heuristics is often exact in practice, while outperforming the exact algorithm. This is an extension of a previous publication, see hal-02302463v1.
0-comments.pdf (674.31 Ko) Télécharger le fichier
hal-03156136 , version 1 (02-03-2021)
hal-03156136 , version 2 (07-05-2021)
hal-03156136 , version 3 (17-06-2021)
  • HAL Id : hal-03156136 , version 2
Emilie Allart, Joachim Niehren, Cristian Versari. Computing Difference Abstractions of Linear Equation Systems. 2021. ⟨hal-03156136v2⟩
160 Consultations
171 Téléchargements
