Geodesics and Curvature of the Quotient-Affine Metrics on Full-Rank Correlation Matrices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Correlation matrices are used in many domains of neurosciences such as fMRI, EEG, MEG. However, statistical analyses often rely on embeddings into a Euclidean space or into Symmetric Positive Definite matrices which do not provide intrinsic tools. The quotient-affine metric was recently introduced as the quotient of the affine-invariant metric on SPD matrices by the action of diagonal matrices. In this work, we provide most of the fundamental Riemannian operations of the quotient-affine metric: the expression of the metric itself, the geodesics with initial tangent vector, the Levi-Civita connection and the curvature.
main.pdf (486.77 Ko) Télécharger le fichier
hal-03157992 , version 1 (05-03-2021)
hal-03157992 , version 2 (09-05-2021)
hal-03157992 , version 3 (11-05-2021)
  • HAL Id : hal-03157992 , version 2
Yann Thanwerdas, Xavier Pennec. Geodesics and Curvature of the Quotient-Affine Metrics on Full-Rank Correlation Matrices. GSI 2021 - 5th conference on Geometric Science of Information, Jul 2021, Paris, France. ⟨hal-03157992v2⟩
264 Consultations
363 Téléchargements
