Bilateral teleoperation with adaptive impedance control for contact tasks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Robotics and Automation Letters Année : 2021
This paper presents an adaptive impedance control architecture for robotic teleoperation of contact tasks featuring continuous interaction with the environment. We use Learning from Demonstration (LfD) as a framework to learn variable stiffness control policies. Then, the learnt state-varying stiffness is used to command the remote manipulator, so as to adapt its interaction with the environment based on the sensed forces. Our system only relies on the on-board torque sensors of a commercial robotic manipulator and it does not require any additional hardware or user input for the estimation of the required stiffness. We also provide a passivity analysis of our system, where the concept of energy tanks is used to guarantee a stable behavior. Finally, the system is evaluated in a representative teleoperated cutting application. Results show that the proposed variablestiffness approach outperforms two standard constant-stiffness approaches in terms of safety and robot tracking performance.
Youssef-RAL21-adaptive-impedance.pdf (972.85 Ko) Télécharger le fichier
Youssef-RAL21-adaptive-impedance (1).pdf (6.6 Mo) Télécharger le fichier
hal-03161641 , version 1 (07-03-2021)
Youssef Michel, Rahaf Rahal, Claudio Pacchierotti, Paolo Robuffo Giordano, Dongheui Lee. Bilateral teleoperation with adaptive impedance control for contact tasks. IEEE Robotics and Automation Letters, 2021, 6 (3), pp.5429-5436. ⟨10.1109/LRA.2021.3066974⟩. ⟨hal-03161641⟩
128 Consultations
1422 Téléchargements
