Limiting Amplitude Principle for a Hyperbolic Metamaterial in Free Space - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2021
Harmonic wave propagation in hyperbolic metamaterials is described by the Maxwell equations with a frequency-dependent tensor of dielectric permittivity. For a range of frequencies, this tensor has eigenvalues of opposite signs, and thus, in two dimensions, the harmonic Maxwell equations can be written as a Klein-Gordon equation. This technical report is mainly dedicated to the proof of the limiting amplitude principle for the simplest case of such a problem, and is a companion to the manuscript.
main_final (1).pdf (377.63 Ko) Télécharger le fichier
hal-03164307 , version 1 (10-03-2021)
  • HAL Id : hal-03164307 , version 1
Maryna Kachanovska. Limiting Amplitude Principle for a Hyperbolic Metamaterial in Free Space. [Research Report] Inria. 2021. ⟨hal-03164307⟩
85 Consultations
62 Téléchargements
