Extreme Partial Least-Squares - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We propose a new approach, called Extreme-PLS, for dimension reduction in conditional extreme values settings. The objective is to find linear combinations of covariates that best explain the extreme values of the response variable in a non-linear inverse regression model. The asymptotic normality of the Extreme-PLS estimator is established in the single-index framework and under mild assumptions. The performance of the method is assessed on simulated data. A statistical analysis of French farm income data, considering extreme cereal yields, is provided as an illustration.
Revision_HAL_ExtremePLS.pdf (5.64 Mo) Télécharger le fichier
hal-03165399 , version 1 (10-03-2021)
hal-03165399 , version 2 (22-03-2022)
hal-03165399 , version 3 (05-09-2022)
  • HAL Id : hal-03165399 , version 2
Meryem Bousebata, Geoffroy Enjolras, Stéphane Girard. Extreme Partial Least-Squares. 2021. ⟨hal-03165399v2⟩
460 Consultations
486 Téléchargements
