RODENT: a flexible TOPSIS based routing protocol for multi-technology devices in wireless sensor networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ITU Journal on Future and Evolving Technologies Année : 2021
Wireless Sensor Networks (WSN) are efficient tools for many use cases, such as environmental monitoring. However WSN deployment is sometimes limited by the characteristics of the Radio Access Technologies (RATs) they use. To overcome some of these limitations, we propose to leverage the use of a Multiple Technologies Network (MTN). What we refer to as MTN is a network composed of nodes which are able to use several RAT and communicating wirelessly through multi-hop paths. The management of the RAT and routes must be handled by the nodes themselves, in a local and distributed way, with a suitable communication protocol stack. Nodes may reach multiple neighbors over multiple RAT. Therefore, each stack's layer has to take the technologies' heterogeneity of the devices into account. In this article, we introduce our custom Routing Over Different Existing Network Technologies protocol (RODENT), designed for MTN. It enables dynamic (re)selection of the best route and RAT based on the data type and requirements that may evolve over time, potentially mixing each technology over a single path. RODENT relies on a multi-criteria route selection performed with a custom lightweight TOPSIS method. To assess RODENT's performances, we implemented a functional prototype on real WSN hardware, Pycom FiPy devices. Unlike related prototypes, ours has the advantage not to rely on specific infrastructure on the operator's side. Results show that RODENT enables energy savings, an increased coverage as well as multiple data requirements support.
main.pdf (1.63 Mo) Télécharger le fichier
hal-03165426 , version 1 (10-03-2021)
hal-03165426 , version 2 (22-03-2021)
hal-03165426 , version 3 (30-03-2021)
  • HAL Id : hal-03165426 , version 3
Brandon Foubert, Nathalie Mitton. RODENT: a flexible TOPSIS based routing protocol for multi-technology devices in wireless sensor networks. ITU Journal on Future and Evolving Technologies, 2021, 2 (1). ⟨hal-03165426v3⟩
356 Consultations
568 Téléchargements
