TT-SLAM: Dense Monocular SLAM for Planar Environments
This paper proposes a novel visual SLAM method with dense planar reconstruction using a monocular camera: TT-SLAM. The method exploits planar template-based trackers (TT) to compute camera poses and reconstructs a multiplanar scene representation. Multiple homographies are estimated simultaneously by clustering a set of template trackers supported by superpixelized regions. Compared to RANSACbased multiple homographies method [1], data association and keyframe selection issues are handled by the continuous nature of template trackers. A non-linear optimization process is applied to all the homographies to improve the precision in pose estimation. Experiments show that the proposed method outperforms RANSAC-based multiple homographies method [1] as well as other dense method SLAM techniques such as LSD-SLAM or DPPTAM, and competes with keypointbased techniques like ORB-SLAM while providing dense planar reconstructions of the environment.
Robotique [cs.RO]
