Higher-Order Spectral Clustering for Geometric Graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Fourier Analysis and Applications Année : 2021
The present paper is devoted to clustering geometric graphs. While the standard spectral clustering is often not effective for geometric graphs, we present an effective generalization, which we call higher-order spectral clustering. It resembles in concept the classical spectral clustering method but uses for partitioning the eigenvector associated with a higher-order eigenvalue. We establish the weak consistency of this algorithm for a wide class of geometric graphs which we call Soft Geometric Block Model. A small adjustment of the algorithm provides strong consistency. We also show that our method is effective in numerical experiments even for graphs of modest size.
Avrachenkov2021_Article_Higher-OrderSpectralClustering.pdf (834.68 Ko) Télécharger le fichier
Origine : Publication financée par une institution
hal-03169834 , version 1 (15-03-2021)
Konstantin Avrachenkov, Andrei Bobu, Maximilien Dreveton. Higher-Order Spectral Clustering for Geometric Graphs. Journal of Fourier Analysis and Applications, 2021, 27, ⟨10.1007/s00041-021-09825-2⟩. ⟨hal-03169834⟩
105 Consultations
135 Téléchargements
