Optimal periodic resource allocation in reactive dynamical systems: Application to microalgal production - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Robust and Nonlinear Control Année : 2023
In this article, we focus on a periodic resource allocation problem applied to a dynamical system which comes from a biological system. More precisely, we consider a system with $N$ resources and $N$ activities, each activity use the allocated resource to evolve up to a given time $T > 0$ where a control (represented by a given permutation) will be applied on the system to reallocate the resources. The goal is to find the optimal control strategies which optimize the cost or the benefit of the system. This problem can be illustrated by an industrial biological application, namely, the optimization of a mixing strategy to enhance the growth rate in a microalgal raceway system. A mixing device, such as a paddle wheel, is considered to control the rearrangement of the depth of the algae cultures, hence the light perceived at each lap. We prove that if the dynamics of the system is periodic, then the period corresponds to one reallocation whatever the order of the involved permutation matrix is. A nonlinear optimization problem for one reallocation process is then introduced. Since $N!$ permutations need to be tested in the general case, it can be numerically solved only for a limited number of $N$. To overcome this difficulty, we introduce a second optimization problem which provides a suboptimal solution of the initial problem, but whose solution can be determined explicitly. A sufficient condition to characterize cases where the two problems have the same solution is given. Some numerical experiments are performed to assess the benefit of optimal strategies in various settings.
hal.pdf (2.38 Mo) Télécharger le fichier
hal-03170481 , version 1 (16-03-2021)
hal-03170481 , version 2 (28-05-2022)
Olivier Bernard, Liu‐di Lu, Julien Salomon. Optimal periodic resource allocation in reactive dynamical systems: Application to microalgal production. International Journal of Robust and Nonlinear Control, 2023, 33 (9), pp.4989-5010. ⟨10.1002/rnc.6171⟩. ⟨hal-03170481v2⟩
170 Consultations
92 Téléchargements
