A distance for evidential preferences with application to group decision making - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Information Sciences Année : 2021
In this paper, we focus on measuring the dissimilarity between preferences with uncertainty and imprecision, modelled by evidential preferences based on the theory of belief functions. Two issues are targeted: The first concerns the conflicting interpretations of incomparability, leading to a lack of consensus within the preference modelling community. This discord affects the value settings of dissimilarity measures between preference relations. After reviewing the state of the art, we propose to distinguish between two cases: indecisive and undecided, respectively modelled by a binary relation and union of all relations. The second concerns a flaw that becomes apparent when measuring the dissimilarity in the theory of belief functions. Existing dissimilarity functions in the theory of belief functions are not suitable for evidential preferences, because they measure the dissimilarity between preference relations as being identical. This is counter-intuitive and conflicting with almost all the related works. We propose a novel distance named Unequal Singleton Pair (USP) distance, able to discriminate specific singletons from others when measuring the dissimilarity. The advantages of USP distances are illustrated by the evidential preference aggregation and group decision-making applications. The experiments show that USP distance effectively improves the quality of decision results.
A_distance_based_aggregation_strategy_for_incomplete_and_uncertain_preferences__v3_-2.pdf (709.39 Ko) Télécharger le fichier
hal-03171577 , version 1 (17-03-2021)
Yiru Zhang, Tassadit Bouadi, Yewan Wang, Arnaud Martin. A distance for evidential preferences with application to group decision making. Information Sciences, 2021, 568, pp.113-132. ⟨10.1016/j.ins.2021.03.011⟩. ⟨hal-03171577⟩
123 Consultations
101 Téléchargements
