Quantifying the overall effect of biotic interactions on species communities along environmental gradients - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
Separating environmental effects from those of biotic interactions on species distributions has always been a central objective of ecology. Despite years of effort in analysing patterns of species co-occurrences and communities and the developments of sophisticated tools, we are still unable to address this major objective. A key reason is that the wealth of ecological knowledge is not sufficiently harnessed in current statistical models, notably the knowledge on biotic interactions. Here, we develop ELGRIN, the first model that combines simultaneously knowledge on species interactions (i.e. metanetwork), environmental data and species occurrences to tease apart the relative effects of abiotic factors and overall biotic interactions on species distributions. Instead of focusing on single effects of pair-wise interactions, which have little sense in complex communities, ELGRIN contrasts the overall effects of biotic interactions to those of the environment. Using simulated and empirical data, we demonstrate the suitability of ELGRIN to address the objectives for various types of interactions like mutualism, competition and trophic interactions. Data on ecological networks are everyday increasing and we believe the time is ripe to mobilize these data to better understand biodiversity patterns. We believe that ELGRIN will provide the unique opportunity to unravel how biotic interactions truly influence species distributions.
ELGRIN.pdf (1.56 Mo) Télécharger le fichier
hal-03172480 , version 1 (18-03-2021)
hal-03172480 , version 2 (10-10-2022)
hal-03172480 , version 3 (09-01-2023)
hal-03172480 , version 4 (28-04-2023)
Vincent Miele, Catherine Matias, Marc Ohlmann, Giovanni Poggiato, Stéphane Dray, et al.. Quantifying the overall effect of biotic interactions on species communities along environmental gradients. 2021. ⟨hal-03172480v1⟩
Collections
LAMA
598 Consultations
222 Téléchargements
