A Lagrangian approach for aggregative mean field games of controls with mixed and final constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
The objective of this paper is to analyze the existence of equilibria for a class of deterministic mean field games of controls. The interaction between players is due to both a congestion term and a price function which depends on the distributions of the optimal strategies. Moreover, final state and mixed state-control constraints are considered, the dynamics being nonlinear and affine with respect to the control. The existence of equilibria is obtained by Kakutani's theorem, applied to a fixed point formulation of the problem. Finally, uniqueness results are shown under monotonicity assumptions.
Bonnans-Gianatti-Pfeiffer.pdf (344.98 Ko) Télécharger le fichier
hal-03174167 , version 1 (18-03-2021)
hal-03174167 , version 2 (17-01-2022)
Joseph Frédéric Bonnans, Justina Gianatti, Laurent Pfeiffer. A Lagrangian approach for aggregative mean field games of controls with mixed and final constraints. 2021. ⟨hal-03174167v1⟩
121 Consultations
204 Téléchargements
