Implicit Implementation of Nonsmooth Controllers to Nonsmooth Actuators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
This paper presents an approach to implement a sliding-mode position controller to a plant equipped with a nonsmooth actuator. The actuator is modeled as a setvalued function from the control input and the velocity to the actuator force, which is motivated by quasistatic characteristics of hydraulic actuators shown in a previous study. The implementation of the sliding-mode controller is performed with the implicit discretization of the nominal plant model and the controller, which copes with the difficulties caused by set-valuedness, such as numerical chattering. Stability analyses both in the continuous-time and discrete-time domains are presented. Simulation results illustrate the theoretical findings.
Kikuuwe_paper_25032021.pdf (2.74 Mo) Télécharger le fichier
hal-03180790 , version 1 (25-03-2021)
hal-03180790 , version 2 (04-02-2022)
  • HAL Id : hal-03180790 , version 1
Ryo Kikuuwe, Yuki Yamamoto, Bernard Brogliato. Implicit Implementation of Nonsmooth Controllers to Nonsmooth Actuators. 2021. ⟨hal-03180790v1⟩
286 Consultations
249 Téléchargements
