Boundary Control for Multi-Directional Traffic on Urban Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
Liudmila Tumash
This paper is devoted to the boundary control design for traffic evolving on large-scale urban networks. The state corresponds to the vehicle density that evolves on a continuum two-dimensional plane. This plane represents an urban network, whose parameters are interpolated as a function of distance to the physical roads. The dynamics of the vehicle density are governed by a newly developed multi-direction traffic flow model called the NSWE-model that encompasses a system of four coupled partial differential equations (PDEs). Each of these PDEs describes the density evolution in one of the four cardinal directions: North, South, West and East. For this model we design a control applied at the network's upstream boundary to drive a multi-directional congested traffic state to a desired equilibrium state. We analyse the class of desired states the system can be driven to. Finally, the result is validated numerically using the real network of Grenoble downtown.
CDC2021_v4.pdf (1.43 Mo) Télécharger le fichier
hal-03182546 , version 1 (26-03-2021)
hal-03182546 , version 2 (24-10-2021)
  • HAL Id : hal-03182546 , version 1
Liudmila Tumash, Carlos Canudas de Wit, Maria Laura Delle Monache. Boundary Control for Multi-Directional Traffic on Urban Networks. 2021. ⟨hal-03182546v1⟩
155 Consultations
268 Téléchargements
