On Trust Confusional, Trust Ignorant, and Trust Transitions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Yoshinobu Kawabe
  • Fonction : Auteur
  • PersonId : 1094573
Yuki Koizumi
  • Fonction : Auteur
  • PersonId : 1094574
Tetsushi Ohki
  • Fonction : Auteur
  • PersonId : 1094575
Masakatsu Nishigaki
  • Fonction : Auteur
  • PersonId : 1094576
Toru Hasegawa
  • Fonction : Auteur
  • PersonId : 1094577
Tetsuhisa Oda
  • Fonction : Auteur
  • PersonId : 1094578
This paper introduces a two-dimensional representation for trust values that uses two metrics: “trust” and “distrust.” With this representation, we can deal with such contradictory arguments as “The message is basically trustworthy but simultaneously not trustworthy.” Such situations can be caused when a message is consistent with other messages, but the message is sent from an unknown sender. We also explore how to analyze the transitions of two-dimensional trust values with a theory of distributed algorithms and compare our trust representation with Jøsang’s subjective logic.
491176_1_En_14_Chapter.pdf (259.35 Ko) Télécharger le fichier
hal-03182612 , version 1 (26-03-2021)
Paternité
Yoshinobu Kawabe, Yuki Koizumi, Tetsushi Ohki, Masakatsu Nishigaki, Toru Hasegawa, et al.. On Trust Confusional, Trust Ignorant, and Trust Transitions. 13th IFIP International Conference on Trust Management (IFIPTM), Jul 2019, Copenhagen, Denmark. pp.178-195, ⟨10.1007/978-3-030-33716-2_14⟩. ⟨hal-03182612⟩
34 Consultations
49 Téléchargements
