From the distributions of times of interactions to preys and predators dynamical systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Mathematical Biology Année : 2023
We consider a stochastic individual based model where each predator searches during a random time and then manipulates its prey or rests. The time distributions may be non-exponential. An age structure allows to describe these interactions and get a Markovian setting. The process is characterized by a measure-valued stochastic differential equation. We prove averaging results in this infinite dimensional setting and get the convergence of the slow-fast macroscopic prey predator process to a two dimensional dynamical system. We recover classical functional responses. We also get new forms arising in particular when births and deaths of predators are affected by the lack of food.
230412.pdf (580.21 Ko) Télécharger le fichier
hal-03183538 , version 1 (29-03-2021)
hal-03183538 , version 2 (18-05-2021)
Vincent Bansaye, Bertrand Cloez. From the distributions of times of interactions to preys and predators dynamical systems. Journal of Mathematical Biology, 2023, 87 (2), ⟨10.1007/s00285-023-01925-5⟩. ⟨hal-03183538v2⟩
78 Consultations
62 Téléchargements
