On the Development of Context-Aware Augmented Reality Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Enes Yigitbas
  • Fonction : Auteur
  • PersonId : 1052710
Ivan Jovanovikj
  • Fonction : Auteur
  • PersonId : 1052712
Stefan Sauer
  • Fonction : Auteur
  • PersonId : 1052714
Gregor Engels
  • Fonction : Auteur
  • PersonId : 1052715
Augmented Reality (AR) is a technique that enables users to interact with their physical environment through the overlay of digital information. With the spread of AR applications in various domains (e.g. product design, manufacturing or maintenance) and the introduction of concepts such as Pervasive Augmented Reality (PAR), the aspect context-awareness started to play an important role. By sensing the user’s current context and adapting the AR application accordingly, an adequate user experience can be achieved. Due to the complex structure and composition of AR applications, their development is a challenging task. Although, context-awareness for AR systems was addressed to some extent, a systematic method for development of context-aware AR applications is not fully covered yet. Therefore, in this paper, we identify the main challenges for development of context-aware AR applications and sketch our solution idea for a model-based development framework. The benefit and applicability of our solution idea is shown on the basis of two example mobile AR applications supporting context-awareness.
486813_1_En_11_Chapter.pdf (2.97 Mo) Télécharger le fichier
hal-03188823 , version 1 (02-04-2021)
Paternité
Enes Yigitbas, Ivan Jovanovikj, Stefan Sauer, Gregor Engels. On the Development of Context-Aware Augmented Reality Applications. 17th IFIP Conference on Human-Computer Interaction (INTERACT), Sep 2019, Paphos, Cyprus. pp.107-120, ⟨10.1007/978-3-030-46540-7_11⟩. ⟨hal-03188823⟩
76 Consultations
65 Téléchargements
