Transverse isotropic modelling of left-ventricle passive filling: mechanical characterization for epicardial biomaterial manufacturing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of the mechanical behavior of biomedical materials Année : 2021
Biomaterials applied to the epicardium have been studied intensively in recent years for different therapeutic purposes. Their mechanical influence on the heart, however, has not been clearly identified. Most biomaterials for epicardial applications are manufactured as membranes or cardiac patches that have isotropic geometry, which is not well suited to myocardial wall motion. Myocardial wall motion during systole and mechanical properties of the LV wall and can serve as a guide for designing and manufacturing biomedical material better adapted to the local epicardial tissue.
JMBBM revised unmarked.pdf (3.05 Mo) Télécharger le fichier
hal-03189522 , version 1 (03-04-2021)
Jean-Philippe Jehl, Pan Dan, Arnaud Voignier, Nguyen Tran, Thierry Bastogne, et al.. Transverse isotropic modelling of left-ventricle passive filling: mechanical characterization for epicardial biomaterial manufacturing. Journal of the mechanical behavior of biomedical materials, 2021, 119, pp.104492. ⟨10.1016/j.jmbbm.2021.104492⟩. ⟨hal-03189522⟩
168 Consultations
355 Téléchargements
