Efficient $\ell^0$ gradient-based Super Resolution for simplified image segmentation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Computational Imaging Année : 2021
We consider a variational model for single-image super-resolution based on the assumption that the gradient of the target image is sparse. We enforce this assumption by considering both an isotropic and an anisotropic $ℓ^0$ regularisation on the image gradient combined with a quadratic data fidelity, similarly as studied in \cite{Storath14} for signal recovery problems. For the numerical realisation of the model, we propose a novel efficient ADMM splitting algorithm whose substeps solutions are computed efficiently by means of hard-thresholding and standard conjugate-gradient solvers. We test our model on highly-degraded synthetic and real-world data and quantitatively compare our results with several sparsity-promoting variational approaches as well as with state-of-the-art deep-learning techniques. Our experiments show that thanks to the $ℓ^0$ smoothing on the gradient, the super-resolved images can be used to improve the accuracy of standard segmentation algorithms for applications like QR codes and cell detection and land-cover classification problems.
hal-03195615 , version 1 (11-04-2021)
Pasquale Cascarano, Luca Calatroni, Elena Loli Piccolomini. Efficient $\ell^0$ gradient-based Super Resolution for simplified image segmentation. IEEE Transactions on Computational Imaging, 2021, 7, pp.399-408. ⟨10.1109/TCI.2021.3070720⟩. ⟨hal-03195615⟩
117 Consultations
0 Téléchargements
