Analysis of a Tripartite Entanglement Distribution Switch - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
Gayane Vardoyan
  • Fonction : Auteur
  • PersonId : 1095769
Saikat Guha
  • Fonction : Auteur
  • PersonId : 1042557
Don Towsley
  • Fonction : Auteur
  • PersonId : 872482
We study a quantum switch that distributes tripartite entangled states to sets of users. The entanglement switching process requires two steps: first, each user attempts to generate bipartite entanglement between itself and the switch; and second, the switch performs local operations and a measurement to create multipartite entanglement for a set of three users. In this work, we study a simple variant of this system, wherein the switch has infinite memory and the links that connect the users to the switch are identical. This problem formulation is of interest to several distributed quantum applications, while the technical aspects of this work result in new contributions within queueing theory. The state of the system is modeled as continuous time Markov chain (CTMC) and performance metrics of interest (probability of an empty system, switch capacity, expectation and variance of the number of qubit-pairs stored) are computed via the solution of a two-dimensional functional equation obtained by reducing it to a boundary value problem on a closed curve. This work is a follow up of [28] where a switch distributing entangled multipartite states to sets of users was studied but only the switch capacity and the expected number of stored qubits were derived.
paper.pdf (803.16 Ko) Télécharger le fichier
hal-03195985 , version 1 (12-04-2021)
hal-03195985 , version 2 (14-04-2021)
hal-03195985 , version 3 (17-04-2021)
hal-03195985 , version 4 (18-09-2021)
hal-03195985 , version 5 (16-01-2022)
  • HAL Id : hal-03195985 , version 2
Philippe Nain, Gayane Vardoyan, Saikat Guha, Don Towsley. Analysis of a Tripartite Entanglement Distribution Switch. 2021. ⟨hal-03195985v2⟩
223 Consultations
346 Téléchargements
