Ideas and perspectives: When ocean acidification experiments are not the same, repeatability is not tested - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Biogeosciences Année : 2021
Can experimental studies on the behavioural impacts of ocean acidification be trusted? That question was raised in early 2020 when a high-profile paper failed to corroborate previously observed responses of coral reef fish to high CO2. New information on the methodologies used in the “replicated” studies now provides a plausible explanation: the experimental conditions were substantially different. High sensitivity to test conditions is characteristic of ocean acidification research; such response variability shows that effects are complex, interacting with many other factors. Open-minded assessment of all research results, both negative and positive, remains the best way to develop process-based understanding. As in other fields, replication studies in ocean acidification are most likely to contribute to scientific advancement when carried out in a spirit of collaboration rather than confrontation.
bg-18-1787-2021.pdf (264.65 Ko) Télécharger le fichier
Origine : Publication financée par une institution
hal-03196460 , version 1 (12-04-2021)
Phillip Williamson, Hans-Otto Pörtner, Steve Widdicombe, Jean-Pierre Gattuso. Ideas and perspectives: When ocean acidification experiments are not the same, repeatability is not tested. Biogeosciences, 2021, 18 (5), pp.1787 - 1792. ⟨10.5194/bg-18-1787-2021⟩. ⟨hal-03196460⟩
118 Consultations
85 Téléchargements
