A Novel Carrier-Cooperation Scheme with an Incentive for Offering Emergency Lightpath Support in Disaster Recovery - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Noboru Yoshikane
  • Fonction : Auteur
  • PersonId : 1096187
Naoki Miyata
  • Fonction : Auteur
  • PersonId : 1096188
Takehiro Tsuritani
  • Fonction : Auteur
  • PersonId : 1096190
Xiaocheng Zhang
  • Fonction : Auteur
  • PersonId : 1096191
To achieve the fast recovery of optical transport networks following a disaster, we investigate a novel scheme to enable cooperation between carriers. Carriers can take advantage of their surviving or recovered optical resources to aid one another with emergency lightpath support to reduce efficiently the burden of recovery, which is heavy immediately after disasters. These lightpaths can be employed exclusively by the counterpart carriers to satisfy their highest priority traffic demands, such as safety confirmation and victim relief. In addition, we introduce an incentive to carriers to prompt cooperation. The carrier cooperation-planning problem is decomposed into eight tasks, and distributed to individual carriers and a third-party organization. During cooperation, the carriers’ confidential information can be strictly protected by employing a carrier optical network abstraction mechanism. The evaluation results reveal that our proposal can significantly reduce the burden on recovery and the corresponding cost for carriers, resulting in fast and efficient disaster recovery.
484327_1_En_31_Chapter.pdf (914.7 Ko) Télécharger le fichier
hal-03200642 , version 1 (16-04-2021)
Paternité
Sugang Xu, Noboru Yoshikane, Naoki Miyata, Masaki Shiraiwa, Takehiro Tsuritani, et al.. A Novel Carrier-Cooperation Scheme with an Incentive for Offering Emergency Lightpath Support in Disaster Recovery. 23th International IFIP Conference on Optical Network Design and Modeling (ONDM), May 2019, Athens, Greece. pp.362-376, ⟨10.1007/978-3-030-38085-4_31⟩. ⟨hal-03200642⟩
38 Consultations
12 Téléchargements
