Network Programmability and Automation in Optical Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
During last years, novel protocols and data models are arising to control and monitor optical network equipment. These protocols enable network programmability and automation by fulfilling the vision introduced by Software Defined Networking (SDN).This paper offers an overview and hands-on experience on programming the necessary tools to control and monitor the network equipment. These tools introduce the necessary network programmability that will enable its automation, following current Zero-Touch service control and management. Data modelling languages are firstly explored. Later, protocols for control and monitoring are presented. Moreover, common standards data models are discussed. Finally, an evaluation of the different presented protocols and data models is provided, which includes recommendations for their selection and deployment.
484327_1_En_20_Chapter.pdf (356.68 Ko) Télécharger le fichier
hal-03200653 , version 1 (16-04-2021)
Paternité
Ricard Vilalta, Ramon Casellas, Ricardo Martínez, Raul Muñoz. Network Programmability and Automation in Optical Networks. 23th International IFIP Conference on Optical Network Design and Modeling (ONDM), May 2019, Athens, Greece. pp.223-234, ⟨10.1007/978-3-030-38085-4_20⟩. ⟨hal-03200653⟩
43 Consultations
29 Téléchargements
