Availability-Guaranteed Slice Provisioning in Wireless-Optical Broadband Access Networks Supporting Mobile Edge Computing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A wireless-optical broadband access network (WOBAN) shows promise as potential 5G access infrastructure. Since network slicing allows efficient sharing of physical network resources, we consider the provisioning of availability-guaranteed slices in a WOBAN supporting mobile edge computing (MEC). A new definition for the availability of a slice is proposed accounting for a slice that functions only partially because of the failure of a fiber link, a microwave link, a base station (BS) node, and/or an optical line terminal (OLT). An integer linear programming (ILP) model and a simple but effective heuristic algorithm that balances the network traffic load and maximizes the slice availability are developed to maximally provision availability-guaranteed slices. Simulation results show the efficiency of the proposed approaches.
484327_1_En_7_Chapter.pdf (517.07 Ko) Télécharger le fichier
hal-03200654 , version 1 (16-04-2021)
Paternité
Ke Chen, Gangxiang Shen, Shuiping Jie, Boping Jiang, Sanjay K. Bose. Availability-Guaranteed Slice Provisioning in Wireless-Optical Broadband Access Networks Supporting Mobile Edge Computing. 23th International IFIP Conference on Optical Network Design and Modeling (ONDM), May 2019, Athens, Greece. pp.70-81, ⟨10.1007/978-3-030-38085-4_7⟩. ⟨hal-03200654⟩
34 Consultations
9 Téléchargements
