Deterministic Contention Management for Low Latency Cloud RAN over an Optical Ring - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The N-GREEN project has for goal the design of a low cost optical ring technology with good performance (throughput, latency$$\dots $$) without using expensive end-to-end connections. We study the compatibility of such a technology with the development of the Cloud RAN, a latency critical application which is a major aspect of 5G deployment. We show that deterministically managing Cloud RAN traffic minimizes its latency while also improving the latency of the other traffics.
484327_1_En_41_Chapter.pdf (297.77 Ko) Télécharger le fichier
hal-03200674 , version 1 (16-04-2021)
Paternité
Dominique Barth, Maël Guiraud, Yann Strozecki. Deterministic Contention Management for Low Latency Cloud RAN over an Optical Ring. 23th International IFIP Conference on Optical Network Design and Modeling (ONDM), May 2019, Athens, Greece. pp.479-491, ⟨10.1007/978-3-030-38085-4_41⟩. ⟨hal-03200674⟩
39 Consultations
3 Téléchargements
