Trophic structure of a nektobenthic community exploited by a multispecific bottom trawling fishery in Northeastern Brazil - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue PLoS ONE Année : 2021
We used complementary stable isotope (SIA) and stomach content (SCA) analyses to investigate feeding relationships among species of the nektobenthic communities and the potential ecological effects of the bottom trawling of a coastal ecosystem in northeastern Brazil. Carbon (δ 13 C) and nitrogen (δ 15 N) compositions were determined for five basal sources and 28 consumers, from zooplankton to shrimp and fish species. Fishes and basal sources showed a broad range of δ 15 N (fishes: 6.49–14.94‰; sources: 2.58–6.79‰) and δ 13 C values (fishes: -23.86 to -13.71‰; sources: -24.32 to -13.53‰), while shrimps and crabs exhibited similar nitrogen and carbon ratios. Six trophic consumer groups were determined among zooplankton, crustaceans and fishes by SIA, with trophic pathways associated mostly with benthic sources. SCA results indicated a preference for benthic invertebrates, mainly worms, crabs and shrimps, as prey for the fish fauna, highlighting their importance in the food web. In overall, differences between SCA and the SIA approaches were observed, except for groups composed mainly for shrimps and some species of high δ 15 N values, mostly piscivorous and zoobenthivores. Given the absence of regulation for bottom trawling activities in the area, the cumulative effects of trawling on population parameters, species composition, potentially decreasing the abundance of benthic preys (e.g., shrimps, worms and crabs) may lead to changes in the trophic structure potentially affect the food web and the sustainability of the fishery.
journal.pone.0246491.pdf (1.68 Mo) Télécharger le fichier
hal-03204169 , version 1 (21-04-2021)
Paternité
Alex Souza Lira, Flávia Lucena-Frédou, Thierry Frédou, Frédéric Ménard, Júlio Guazzelli Gonzalez, et al.. Trophic structure of a nektobenthic community exploited by a multispecific bottom trawling fishery in Northeastern Brazil. PLoS ONE, 2021, 16 (2), pp.e0246491. ⟨10.1371/journal.pone.0246491⟩. ⟨hal-03204169⟩
180 Consultations
69 Téléchargements
