Recent results for the Landau-Lifshitz equation
We give a survey on some recent results concerning the Landau-Lifshitz equation, a fundamental nonlinear PDE with a strong geometric content, describing the dynamics of the magnetization in ferromagnetic materials. We revisit the Cauchy problem for the anisotropic Landau-Lifshitz equation, without dissipation, for smooth solutions, and also in the energy space in dimension one. We also examine two approximations of the Landau-Lifshitz equation given by of the Sine-Gordon equation and cubic Schrödinger equations, arising in certain singular limits of strong easy-plane and easy-axis anisotropy, respectively.
Concerning localized solutions, we review the orbital and asymptotic stability problems for a sum of solitons in dimension one, exploiting the variational nature of the solitons in the hydrodynamical framework.
Finally, we survey results concerning the existence, uniqueness and stability of self-similar solutions (expanders and shrinkers) for the isotropic LL equation with Gilbert term. Since expanders are associated with a singular initial condition with a jump discontinuity, we also review their well-posedness in spaces linked to the BMO space.
Recent results for the Landau-Lifshitz equation.pdf (3.25 Mo)
Télécharger le fichier
