Exponential convergence towards consensus for non-symmetric linear first-order systems in finite and infinite dimensions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Mathematical Analysis Année : 2022
We consider finite and infinite-dimensional first-order consensus systems with timeconstant interaction coefficients. For symmetric coefficients, convergence to consensus is classically established by proving, for instance, that the usual variance is an exponentially decreasing Lyapunov function. We investigate here the convergence to consensus in the non-symmetric case: we identify a positive weight which allows to define a weighted mean corresponding to the consensus, and obtain exponential convergence towards consensus. Moreover, we compute the sharp exponential decay rate.
bst.pdf (949.94 Ko) Télécharger le fichier
hal-03210969 , version 1 (28-04-2021)
Laurent Boudin, Francesco Salvarani, Emmanuel Trélat. Exponential convergence towards consensus for non-symmetric linear first-order systems in finite and infinite dimensions. SIAM Journal on Mathematical Analysis, 2022, 54 (3), pp.2727--2752. ⟨10.1137/21m1416102⟩. ⟨hal-03210969⟩
132 Consultations
121 Téléchargements
