Overrelaxed Sinkhorn-Knopp Algorithm for Regularized Optimal Transport - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Algorithms Année : 2021
This article describes a set of methods for quickly computing the solution to the regularized optimal transport problem. It generalizes and improves upon the widely used iterative Bregman projections algorithm (or Sinkhorn-Knopp algorithm). We first proposed to rely on regularized nonlinear acceleration schemes. In practice, such approaches lead to fast algorithms, but their global convergence is not ensured. Hence, we next proposed a new algorithm with convergence guarantees. The idea is to overrelax the Bregman projection operators, allowing for faster convergence. We proposed a simple method for establishing global convergence by ensuring the decrease of a Lyapunov function at each step. An adaptive choice of the overrelaxation parameter based on the Lyapunov function was constructed. We also suggested a heuristic to choose a suitable asymptotic overrelaxation parameter, based on a local convergence analysis. Our numerical experiments showed a gain in convergence speed by an order of magnitude in certain regimes.
hal.pdf (706.23 Ko) Télécharger le fichier
hal-03212175 , version 1 (29-04-2021)
Alexis Thibault, Lénaïc Chizat, Charles Dossal, Nicolas Papadakis. Overrelaxed Sinkhorn-Knopp Algorithm for Regularized Optimal Transport. Algorithms, 2021, Optimal Transport: Algorithms and Applications, 14 (5), ⟨10.3390/a14050143⟩. ⟨hal-03212175⟩
125 Consultations
381 Téléchargements
