Cartan connections and path structures with large automorphisms groups - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Mathematics Année : 2021
We classify compact manifolds of dimension three equipped with a path structure and a fixed contact form (which we refer to as a strict path structure) under the hypothesis that their automorphism group is non-compact. We use a Cartan connection associated to the structure and show that its curvature is constant.
strictpathstructures-2.1-m.pdf (290.54 Ko) Télécharger le fichier
hal-03214060 , version 1 (05-05-2021)
hal-03214060 , version 2 (02-03-2023)
Elisha Falbel, Martin Mion-Mouton, Jose Miguel Veloso. Cartan connections and path structures with large automorphisms groups. International Journal of Mathematics, 2021, ⟨10.1142/S0129167X21400164⟩. ⟨hal-03214060v1⟩
111 Consultations
181 Téléchargements
