Variance Optimization and Control Regularity for Mean-Field Dynamics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
Benoît Bonnet
We study a family of optimal control problems in which one aims at minimizing a cost that mixes a quadratic control penalization and the variance of the system, both for finitely many agents and for the mean-field dynamics as their number goes to infinity. While solutions of the discrete problem always exist in a unique and explicit form, the behavior of their macroscopic counterparts is very sensitive to the magnitude of the time horizon and penalization parameter. When one minimizes the final variance, there always exists a Lipschitz-in-space optimal controls for the infinite dimensional problem, which can be obtained as a suitable extension of the optimal controls for the finite-dimensional problems. The same holds true for variance maximizations whenever the time horizon is sufficiently small. On the contrary, for large final times (or equivalently for small penalizations of the control cost), it can be proven that there does not exist Lipschitz-regular optimal controls for the macroscopic problem.
LipRegConf.pdf (756.56 Ko) Télécharger le fichier
Format : Figure, Image
hal-03216326 , version 1 (03-05-2021)
hal-03216326 , version 2 (29-07-2021)
  • HAL Id : hal-03216326 , version 2
Benoît Bonnet, Francesco Rossi. Variance Optimization and Control Regularity for Mean-Field Dynamics. 2021. ⟨hal-03216326v2⟩
50 Consultations
66 Téléchargements
