Combinatorics of Serre weights in the potentially Barsotti-Tate setting - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
Let $F$ be a finite unramified extension of $\mathbb{Q}_p$ and $\bar\rho$ be a absolutely irreducible mod~$p$ $2$-dimensional representation of the absolute Galois group of $F$. Let also $t$ be a tame inertial type of $F$. We relate the Kisin variety associated to these data to the set of Serre weights $\mathcal{D}(t,\bar\rho) = \mathcal{D}(t) \cap \mathcal{D}(\bar\rho)$. We prove that the Kisin variety enriched with its canonical embedding into $(\mathbb{P}^1)^f$ and its shape stratification are enough to determine the cardinality of $\mathcal{D}(t,\bar\rho)$. Moreover, we prove that this dependance is nondecreasing (the smaller is the Kisin variety, the smaller is the number of common Serre weights) and compatible with products (if the Kisin variety splits as a product, so does the number of weights). These results provide new evidences towards the conjectures in our previous paper.
combiSerre.pdf (623.02 Ko) Télécharger le fichier
hal-03221168 , version 1 (07-05-2021)
hal-03221168 , version 2 (10-05-2021)
hal-03221168 , version 3 (05-11-2021)
Xavier Caruso, Agnès David, Ariane Mézard. Combinatorics of Serre weights in the potentially Barsotti-Tate setting. 2021. ⟨hal-03221168v2⟩
296 Consultations
97 Téléchargements
