Experimental Comparison of Semi-parametric, Parametric, and Machine Learning Methods for Time-to-Event Analysis Through the IPEC Score
In this paper, we make an experimental comparison of semi-parametric (Cox proportional hazards model, Aalen additive model), parametric (Weibull AFT model), and machine learning methods (Random Survival Forest, Gradient Boosting Cox proportional hazards loss, DeepSurv) through the IPEC score on three different datasets (PBC, GBCSG2 and TLCM).
