Experimental Comparison of Semi-parametric, Parametric, and Machine Learning Methods for Time-to-Event Analysis Through the IPEC Score - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we make an experimental comparison of semi-parametric (Cox proportional hazards model, Aalen additive model), parametric (Weibull AFT model), and machine learning methods (Random Survival Forest, Gradient Boosting Cox proportional hazards loss, DeepSurv) through the IPEC score on three different datasets (PBC, GBCSG2 and TLCM).
JDS_20210508.pdf (640.86 Ko) Télécharger le fichier
hal-03221512 , version 1 (08-05-2021)
  • HAL Id : hal-03221512 , version 1
Camila Fernández, Chung Shue Chen, Pierre Gaillard, Alonso Silva. Experimental Comparison of Semi-parametric, Parametric, and Machine Learning Methods for Time-to-Event Analysis Through the IPEC Score. SFdS 2020 - 52èmes Journées de Statistiques de la Société Française de Statistique, Jun 2021, Nice, France. pp.1-6. ⟨hal-03221512⟩
143 Consultations
115 Téléchargements
