A Model for Evaluating Big Data Analytics Tools for Organisation Purposes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Phaphama Kangelani
  • Fonction : Auteur
  • PersonId : 1098393
Tiko Iyamu
  • Fonction : Auteur
  • PersonId : 1098394
Big data analytics tools have many functions that are common or similar to one another. This is a problem for many organisations that are either interested or have deployed some of the tools. The problem arises because there is no mechanism on how to determine appropriateness of the tools within context in an environment. Some of the implications of the problem are that it is difficult to assess appropriateness of the tools in an environment, which sometimes result to duplication; and the value of the tools. The aim of this project was to propose a solution through a model that can be used to evaluate big data analytics tools for organisations’ benefits. The qualitative method, case study approach and semi-structured interview technique were applied in the study. From the analysis, the role of criteria, business and IT alignment, governance, and skill-sets were revealed as critical factors. Based on the factors, a model was developed, which can be used as a building block through which evaluation of big data analytics tools in an organisation is carried out.
492453_1_En_41_Chapter.pdf (205.43 Ko) Télécharger le fichier
hal-03222843 , version 1 (10-05-2021)
Paternité
Phaphama Kangelani, Tiko Iyamu. A Model for Evaluating Big Data Analytics Tools for Organisation Purposes. 19th Conference on e-Business, e-Services and e-Society (I3E), Apr 2020, Skukuza, South Africa. pp.493-504, ⟨10.1007/978-3-030-44999-5_41⟩. ⟨hal-03222843⟩
52 Consultations
11 Téléchargements
