Videoconferencing using Spatially Varying Sensing with Multiple and Moving Foveae - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1994
A new method for videoconferencing using the concept of spatially varying sensing is introduced. Various techniques are discussed for combining information obtained from multiple points-of-interest (foveae) in an image. A fovea can be used to follow a moving bbject of interest as well. A fast videoconferencing prototype for desktop computers is also described.
13. Videoconferencing using spatially varying sensing with multiple and moving foveae.pdf (816.19 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
hal-03224853 , version 1 (12-05-2021)
Anup Basu, Kevin James Wiebe. Videoconferencing using Spatially Varying Sensing with Multiple and Moving Foveae. 12th IAPR International Conference on Pattern Recognition, Oct 1994, Jérusalem, Israel. pp.30-34, ⟨10.1109/ICPR.1994.577116⟩. ⟨hal-03224853⟩
75 Consultations
19 Téléchargements
