Integrating active face tracking with model based coding - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Pattern Recognition Letters Année : 1999
In this paper, input from an active camera is used for MPEG4 model based coding. First, the background is compensated considering a moving camera (tilt or pan). Second, the talking face is segmented from the compensated background using frame dierences fusion. A morphological ®lter is then applied to make the system less sensitive to noise. Third, Hough Transform and deformable template coupled with color information are exploited to detect the facial features, e.g., eyes, mouth. Fourth, a wireframe model is adapted to the extracted face. The feasibility of the proposed system is demonstrated using a real active video sequence.
15. Integrating active face tracking with model based coding.pdf (421.1 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
hal-03224859 , version 1 (12-05-2021)
Lijun Yin, Anup Basu. Integrating active face tracking with model based coding. Pattern Recognition Letters, 1999, 20 (6), pp.651-657. ⟨10.1016/S0167-8655(99)00029-X⟩. ⟨hal-03224859⟩
83 Consultations
37 Téléchargements
