Estimation of the tail-index and extreme quantiles from a mixture of heavy-tailed distributions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The estimation of extreme quantiles requires adapted methods to extrapolate beyond the largest observation of the sample. Extreme-value theory provides a mathematical framework to tackle this problem together with statistical procedures based on the estimation of the so-called tail-index describing the distribution tail. We focus on heavy-tailed distributions and consider the case where the shape of the distribution tail depends on unknown auxiliary variables. As a consequence, one has to deal with observations from a mixture of heavytailed distributions, and it is shown that, in such a situation, usual extreme-value estimators suffer from a strong bias. We propose several methods to mitigate this bias. Their asymptotic properties are established and their finite sample performance is illustrated both on simulated and real financial data This is joint work with Emmanuel Gobet.
352936.pdf (76.94 Ko) Télécharger le fichier
slides_RESIM_2021.pdf (508.38 Ko) Télécharger le fichier
hal-03235031 , version 1 (25-05-2021)
  • HAL Id : hal-03235031 , version 1
Stéphane Girard, Emmanuel Gobet. Estimation of the tail-index and extreme quantiles from a mixture of heavy-tailed distributions. RESIM 2021 - 13th International Workshop on Rare-Event Simulation, May 2021, Paris / Virtual, France. pp.1. ⟨hal-03235031⟩
109 Consultations
163 Téléchargements
