Bridging the Multiscale Hybrid-Mixed and Multiscale Hybrid High-Order methods - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Mathematical Modelling and Numerical Analysis Année : 2021
We establish the equivalence between the Multiscale Hybrid-Mixed (MHM) and the Multiscale Hybrid High-Order (MsHHO) methods for a variable diffusion problem with piecewise polynomial source term. Under the idealized assumption that the local problems defining the multiscale basis functions are exactly solved, we prove that the equivalence holds for general polytopal (coarse) meshes and arbitrary approximation orders. We also leverage the interchange of properties to perform a unified convergence analysis, as well as to improve on both methods.
mhmhho.pdf (468.41 Ko) Télécharger le fichier
hal-03235525 , version 1 (25-05-2021)
hal-03235525 , version 2 (07-12-2021)
hal-03235525 , version 3 (07-01-2022)
Théophile Chaumont-Frelet, Alexandre Ern, Simon Lemaire, Frédéric Valentin. Bridging the Multiscale Hybrid-Mixed and Multiscale Hybrid High-Order methods. ESAIM: Mathematical Modelling and Numerical Analysis, In press, ⟨10.1051/m2an/2021082⟩. ⟨hal-03235525v2⟩
246 Consultations
139 Téléchargements
