Multi-stage Stochastic Alternating Current Optimal Power Flow with Storage: Bounding the Relaxation Gap - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
Maxime Grangereau
  • Fonction : Auteur correspondant
  • PersonId : 1099730
Connectez-vous pour contacter l'auteur
EDF
Wim van Ackooij
  • Fonction : Auteur
EDF
Stéphane Gaubert
We propose a generic multistage stochastic model for the Alternating Current Optimal Power Flow (AC OPF) problem for radial distribution networks, to account for the random electricity production of renewable energy sources and dynamic constraints of storage systems. We consider single-phase radial networks. Radial three-phase balanced networks (medium-voltage distribution networks typically have this structure) reduce to the former case. This induces a large scale optimization problem, which, given the non-convex nature of the AC OPF, is generally challenging to solve to global optimality. We derive a priori conditions guaranteeing a vanishing relaxation gap for the multi-stage AC OPF problem, which can thus be solved using convex optimization algorithms. We also give an a posteriori upper bound on the relaxation gap. In particular, we show that a null or low relaxation gap may be expected for applications with light reverse power flows or if sufficient storage capacities with low cost are available. Then, we discuss the validity of our results when incorporating voltage regulation devices. Finally, we illustrate our results on problems of planning of a realistic distribution feeder with distributed solar production and storage systems. Scenario trees for solar production are constructed from a stochastic model, by a quantile-based algorithm.
Article_opf_EPSR_short (1).pdf (855.97 Ko) Télécharger le fichier
hal-03236238 , version 1 (26-05-2021)
hal-03236238 , version 2 (29-09-2021)
hal-03236238 , version 3 (17-11-2021)
Maxime Grangereau, Wim van Ackooij, Stéphane Gaubert. Multi-stage Stochastic Alternating Current Optimal Power Flow with Storage: Bounding the Relaxation Gap. 2021. ⟨hal-03236238v2⟩
144 Consultations
129 Téléchargements
