A generative model for fBm with deep ReLU neural networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
We provide a large probability bound on the uniform approximation of fractional Brownian motion $(B^H(t) : t ∈ [0,1])$ with Hurst parameter $H$, by a deep-feedforward ReLU neural network fed with a $N$-dimensional Gaussian vector, with bounds on the network construction (number of hidden layers and total number of neurons). Essentially, up to log terms, achieving an uniform error of $\mathcal{O}(N^{-H})$ is possible with log$(N)$ hidden layers and $\mathcal{O} (N \log N)$ parameters. Our analysis relies, in the standard Brownian motion case $(H = 1/2)$, on the Levy construction of $B^H$ and in the general fractional Brownian motion case $(H \ne 1/2)$, on the Lemarié-Meyer wavelet representation of $B^H$. This work gives theoretical support on new generative models based on neural networks for simulating continuous-time processes.
fBm-HAL-v3.pdf (12.14 Mo) Télécharger le fichier
hal-03237854 , version 1 (26-05-2021)
hal-03237854 , version 2 (16-06-2021)
hal-03237854 , version 3 (26-01-2022)
hal-03237854 , version 4 (25-04-2022)
  • HAL Id : hal-03237854 , version 3
Michaël Allouche, Stéphane Girard, Emmanuel Gobet. A generative model for fBm with deep ReLU neural networks. 2022. ⟨hal-03237854v3⟩
612 Consultations
397 Téléchargements
